Re: charging system testing on 1966 40hp johnson
Clint.... You can test the generator itself by connecting a small jumper from the field terminal of the gen (smaller of the two terminals) to ground, then connect the positive lead of a volt meter to the gen armature terminal, and the volt meter ground terminal to ground. If the generator's okay, at idle of course, you'll see no charge, but as you increase rpms, the meter will register the voltage charge rate.<br /><br />You can also do the above test with the generator removed from the engine by simply holding the gen pulley up against the wire wheel of an electric grinder.<br /><br />When you know that a generator is okay (as above), and no charge rate is indicated on the dash amp gauge, obviously the regulator is questionable.
