Re: charging dual batteries
Yes. Now, there will be 50 additional comments, but here is the gist...
*Use a battery charger like the dual-bank Battery Tender with the battery switch set to OFF. You don't want to have a constant charging current going into the battery when it isn't needed. A quality trickle charger will top off the batteries and then go into a monitor mode and only kick on when necessary.
* It is better to unhook them or turn the battery selector to OFF if you only have a single bank charger. Doing this will make you charge one battery at a time. I can't think of any reason that leaving them hooked up would cause a problem, but if I'm missing something, someone will sure chirp in.
* Make sure the compartment/area where the batteries are kept is well ventilated during charging.
* Make sure the battery cells are topped off with electrolytes or distilled water prior to charging.
