tightstripes
Thread starter- Joined
- Jul 21, 2009
- 22
is it possible to charge a marine starting battery too much. If i charge it after each use, will that lower the batteries life expectancy\\??
If you use an old fashioned transformer-rectifier battery charger, then yes. If you use a modern electronically supervised charger (usually has a readout), then no.
The main item for long battery life is don't let the electrolyte level get too low.
hope it helps
John
