Chapparal 206 cushion removal
Crazedhick3
2010 Chapparal 206 ssi
I am prepping to reupholster entire boat and am in need of removing the front cushions mounted to the gunnel. Any idea how to access the bottom fasteners? I can’t get my hand far enough in there. There has to be a way right? Pic posted.
tpenfield
Some cushions are not screwed in from behind, but are mounted with 'Z' brackets and hold-down straps.
If you can see a metal plate/strap right below the cushion, then it is a fair bet that the cushion is held on that way.
tpenfield
Are you sending the cushions out to an upholstery shop or DIY?
