changing VRO fuel pump on 85 120
ferro762
I think I might have a fuel pump problem on my 85 120 looper. I pre mix and was wodering what fuel pump ill need to switch to without the oil pump. Ive been trying to look it up and im not getting anywhere. Could someone help me out on what model pump i need, I would really appreciate it. thanks.
Matt
Dhadley
Re: changing VRO fuel pump on 85 120
There is a pump without the oil side, it's about 40.00 cheaper if I emember right. Why do you think you need a new fuel pump?
ferro762
when the motor turns over it revs up and down a couple rmp. It will be at 20 for a few sec then goto 17-18 then back up. One of the spark plugs I think in 1st cylinder ( if looking from stern to bow it's the top right cylinder) keeps turning blk. ive taken apart carb 1 & 3, i think i cleaned them. they were just done 2 months ago. its been running great since i got it back from shop, i started it every week, took it out 2 times and besides a spun hub it ran great. then i was out and when i would idle the motor would stall, then it got to the point where it wouldnt turn over anymore. i changed the plugs it runs now just does what i said above. last night i was running it and it revs really high for a few sec then stalls, did that a couple times then when it stayed on the bulb didnt feel hard i would squeeze it and it seemed like after a few pumps the motor would power up strong but then go back to what its been doing. someone mentioned the fuel recircuation valve, I havent tried that yet but i was going to see what happend and if that didnt work i was going to try a new pump. any suggestions? thanks!
