Boilermaker
Thread starter- Joined
- Sep 28, 2003
- 388
My boat (1971 Westwind 180) has the steering cable achored to the transome with a ball-bracket, and then a rod going straight to the steering arm on the engine.<br /> The steering cable was replaced years ago and has a large "U" shaped bow in it>>>probably about an extra foot or more of cable then the boat needs in this configuration.<br /><br />The engine (1978 Johnson 115) has the tilt tube that has plastic screw-on caps on it now. What would be necessary to change it to the tilt tube type steering??? And is there any big benifit to this type over what I now have????<br /><br />I am thinking of changing it because I want to raise the engine hight on the transome. I will have to enlarge, or notch the engine well opening to give vertical clearance for the steering arm if I raise the engine the way it is set up now.
