Re: changing ratios
since:
need special tool(s) to properly install upper gears (cost and labor)
never hurts to check / change the u-joints (adds cost and labor)
Gears and the above will easily run over 500 by the time you're done
You can buy a new, complete upper with new heavy duty U-Joints and a warranty for $600 from sei.
Assuming your lower unit is in good shape like mine is...
This wound up to be the best, most cost effective solution to swap gear ratios on my drive...
That being said; If the lower is an unknown, and you have to give more than a "song" for the 1.98 ratio drive, the complete sei drive for ca. 1100 is a no brainer...
just my two cents...
