Hello,
I am looking at replacing the 1978 85 HP Evirude on my boat with a 1988 Evinrude 88SPL. My questions are:
1. Will the throttle and shift cables used on my 85 work on the newer 88?
2. Will the wiring harness on my 1978 85 HP work for the newer 88 SPL?
3. It appears the gear ratios are different 2.29:1 on old 85 and 2.0:1 on newer 88SPL. Can I use prop from my older 85 on the newer 88SPL? The prop on 88 SPL is shot.
4. Is there anything else I should be considering with such a change?
Thanks - any and all help is appreciated.
