CHANGING OUT THE TILT/TRIM MOTOR.<br />GOT THE STARBOARD BRACKET LOOSE.<br />NEED TO REMOVE THE TILT TUBE NUT ON<br />THE STEERING.<br />THE STEERING CABLE RETAINING NUT WILL<br />NOT LOOSEN ALL THE WAY...<br />IS IT LEFT OR RIGHT HAND THREADS?<br />THERE ARE TWO NUTS ON STEERING CABLE.<br />NEED TO REMOVE OR LOOSEN ENOUGHT FOR<br />THE MANUAL RELEASE VALVE TO CLEAR THE<br />STARBOARD MOTOR BRACKET!!<br />ANY SUGGESTIONS!!
