Changing motors - old wires work? Splice?
samm835
In the middle of the summer I changed motors, I went from a Merc 60 bigfoot(94) to a Merc 140 (79). I never had the chance to finish the job, I am using the same steering and I hope to use the same electrical wiring. The difference is the plug to the motor, can I splice the wire from the old to new and wrap up and be ok? I know there is a way because I asked this question earlier in the year when I started, but I am now unable to find it on here. Can someone give me what wires should be connected to the old to new? Thanks for the help!
tashasdaddy
Re: Changing motors - old wires work? Splice?
Samm, if you click on your name, you will get a drop down menu, click all post by Samm835, you will find your old post.
Chris1956
Honorary Supreme Mariner
Sam, I went from a '77 mrc to a '93 Merc. I butt spliced the new wiring harness to the old controls. I looked at each of the wiring diagrams, and made up a cross-connect chart. I do not remember all the colors, but here are some of them.
Old motor brown wire connects to new control grey for tach
Yellow starter solenoid wire is same on both
old motor orange wire connects to new control black/yellow wire to kill ignition.
old motor white wire connects to new control purple wire for Switched +12V
solid Black is ground for both
old motor has grey choke wire. I do not remember new color
Red wire is unswitched +12VDC for both
Tan wire is overheat alarm on new control, unused on old motor
blue/white is PTT up wire on both; Green/white is PTT down wire on both;
That should be most of them
samm835
thanks for ya'lls help.....hopefully I will have this done this weekend so I can start to WINTERIZE WHOO HOOOOOOO (NOT)
