Changing Gear Oil when No Upper Vent
IBashaw
Hi Folks <br />I have a 1975ish 4Hp Evinrude that is overdue for a gear oil change. How do you know when the unit is full when you don't have the usual / typical upper vent hole. I do not see anything that looks like it would be a vent hole screw...nothing. Help!! :confused:
marinemech1
Re: Changing Gear Oil when No Upper Vent
i can't acess parts diagram but there should be a vent usually near anti cavition plate
Xcusme
LordSheffield , Welcome to iboats ! :) <br /><br />You don't have a vent screw on your motor. With motor in an upright position, remove the lower unit drain screw. Lube will drain out.<br />Lay motor on it's side and refill lower unit with lube slightly below drain opening. Replace drain plug and washer to prevent water intrusion into lower unit.
IBashaw
Originally posted by Xcusme:<br /> LordSheffield , Welcome to iboats ! :) <br /><br />You don't have a vent screw on your motor. With motor in an upright position, remove the lower unit drain screw. Lube will drain out.<br />Lay motor on it's side and refill lower unit with lube slightly below drain opening. Replace drain plug and washer to prevent water intrusion into lower unit.
IBashaw
... thanks tons. I was sure that I was not missing it, thanks for confirming and also for the guidance. <br />Any reason why not to use Yamaha gear fluid (which I use in my 2004 15Hp Yamaha outboard) in my older Evrinrude??<br /><br />Ian
Xcusme
The Yamaha gear fluid should work a treat.
