Changing from a Mando Alternator to a single-wire Alternator: Wiring problems
Corto
Hello,
I'm doing a lot of work on my 1991 Bayliner Capri with a 5.0L Mercruiser V8 and I am overhauling most of the electrics.
I've just fitted a new high-output single wire alternator to replace the old one (Mando-type I think) and I don't know what to do with the purple and red/purple excitation wires.
The earth and orange wire to the starter motor have been wired correctly and the motor was starting and running OK this weekend but I think that the alternator wasn't charging because:
a) I was getting no more than 12.5V at the battery when running the engine
b) There is no increase in voltage after starting the engine, and when revving the engine.
I connected the purple and red/purple wires back to a +ve terminal but that made no change to the voltage in the system.
Should I leave them isolated or connect them back to a +ve?
Is my alternator definitely not charging?
(BTW, I noticed that the alternator belt could do with some tightening but that shouldn't be the issue as the alternator is turning with the engine.)
thanks for your help
Bt Doctur
Re: Changing from a Mando Alternator to a single-wire Alternator: Wiring problems
With the engine off, is there voltage at the Orange wire where it hooks to the Alt.?
Corto
Don't know. Will have to check and get back to you tomorrow.
Corto
Yes there is.
Its probably also worth pointing out that the purple and red/purple wires always have voltage, even with the ignition off. Previous owners have by-passed a lot of things in the wiring of this boat.
