Changing from a Mando Alternator to a single-wire Alternator: Wiring problems
Corto
Hello,
I'm doing a lot of work on my 1991 Bayliner Capri with a 5.0L Mercruiser V8 and I am overhauling most of the electrics.
I've just fitted a new high-output single wire alternator to replace the old one (Mando-type I think) and I don't know what to do with the purple and red/purple excitation wires.
The earth and orange wire to the starter motor have been wired correctly and the motor was starting and running OK this weekend but I think that the alternator wasn't charging because:
a) I was getting no more than 12.5V at the battery when running the engine
b) There is no increase in voltage after starting the engine, and when revving the engine.
I connected the purple and red/purple wires back to a +ve terminal but that made no change to the voltage in the system.
Should I leave them isolated or connect them back to a +ve?
Is my alternator definitely not charging?
(BTW, I noticed that the alternator belt could do with some tightening but that shouldn't be the issue as the alternator is turning with the engine.)
thanks for your help
Chris1956
Honorary Supreme Mariner
Re: Changing from a Mando Alternator to a single-wire Alternator: Wiring problems
I recommend you repost this in the I/O forum....
Corto
thanks, will do so.
