dgopetactical
Thread starter- Joined
- Jul 3, 2007
- 509
1988 mercruiser 5.7 alpha 1
hi everyone,
Here is my latest problem. I winterized the boat today and I startd out by replacing the upper pump parts including the impeller on the seawater pump.
I went by the book everything went well except I had trouble when I was putting the lower on it hung up about an inch from the upper drive i jiggled it alittle it it mated up ( it kicked my butt). This was my 1st time doing this and i was very happy when done.
I continued on with the winterizing I put the the muffs on engine started well. I throtttled up and the prop started going in forward gear. I want back to neautral and it stopped. I then put it in forward the engine stalled Istarted it back up and put it in reverse and it stalled again. Here is a run down of this problem
1. seem to be in gear when you push the throttle button and throttle up.
2. stalls when put into forward or reverse
3. with engine off in forward gear if you move the prop by hand to the right you hear a click and if you move it to the left it free spins and it free spins both ways in reverse.
4. shifter is very stiff now was loose before
i dont know what i did wrong, I had the shifter in forward the whole time when i pulled the lower I did not mess with anything and I followed the directions.
I have not had any drive issues prior to this issue.
I even made shure the shifter on the lower was to the right (forward) before putting it back together.
I finished winterizing and tarping it because of time restraints and figured I wait and see what you guys think.
Please let me know what you guys think I need help with this one!!
thanks
Denny
hi everyone,
thanks
Denny
