Boatin Bob
- Sep 24, 2001
- 1,858
Re: Changed fluids myself for first time - am I okay?
I'm surprised there is no fitting, I've had an 87, 2 88's and now 2 89's and they all had it but maybe they stopped it in the 90's. It sounds like you are OK with the lower unit lube but just give it another check before you launch and top it up if needed. You should pick yourself up one of the lower unit lube pumps that screws into the hole, it really will force the lube up into the drive right out the dipstick hole, they are fairly cheap and a lot less messy.....good luck!
