Change the red/red-white, blue etc etc
ixs
When changing the cables from the stator at the box. to see if the trouble with week spark on the eg number 1 and 2 coil. Can one change only the red with the red/white? Or only the blue with the blue/white?
The spark get so week that over 2000 rpm, it runs on two cyl of four.
After I changed the cables, all four.
It was worse than before.
Checking the ohm, is very difficult. the reading is all over the scale.
So two cables or four?
j_martin
Re: Change the red/red-white, blue etc etc
The red and blue are connected to the same coil, as are the red/w and blue/w.
The ohmmeter is used on disconnected wires with nothing running.
Have you checked the ground connection on the stator, which may be by a mounting screw, or may be by a wire coming out with the others.
hope it helps
John
