Re: Chang oil in volvo 270 outdrive
Hi Joshua, welcome to iboats!<br /><br />The drain plug is just above the bottom fin in the lower gear housing. The fill plug is also the dipstick, smack bang centre of the upper gear housing. Change both plug seals, check the level with the dipstick NOT screwed in. The oil goes in slow and will take a bit of time to settle (air pockets). After filling, recheck the next day. You'll need about 3 quarts of 10w30 engine oil, SG or better. (AKA, VP gear oil). Get yourself a manual, it will guide you in the future.<br /><br />Aldo
