cdm ignition system
vettman
Hey all; Of these three electronic componets, -- trigger, stator, cdm modules,-- can either or all function badly at idle, but preform well at higher rpm's ? I guess what i mean do these items either work or not work or can there be some in between ? Have rough idle but runs great over 2000 rpm. Carbs, fuel pump,fuel hoses ,filters,compression, link & sync, plugs, reeds all check out ok. Doesn't matter hot or cold. 2000 90 hp 3cyl. merc. 2 stroke. Thanks for any info.---- P. S. Are these 3 items prone to fail or pretty reliable?
Faztbullet
Re: cdm ignition system
A bad CDM module can cause weird thing as all 3 are connected together thru the harness as with the stator as it could have low voltage to cdm modules. Better to go to CDI website and download troubleshooting manual and get a DVA to test beforethrowing parts at it.
aussieflash
Did you do the checking or a mechanic?From what you say,I would double check for good spark,Reed valves and timing.
vettman
Aussieflash. Mechanic did the above things . Top cyl. seems to be less responsive when plug wire is takin off while running, compared to the other two during same test. He did not do any other electical tests to motor . I may have to have that done . Where can i get a dva and will it test all three items i mentioned? i have the clymers manual . Will that get me by to do tests myself ? Thanks
oldman570
CharlieB has it right on. At 1manual.com it gives all the test procedures for testing the ing. system for your motor. It also states " Intermittent, weak, or no spark at any one spark
plug usually indicates a bad SPARK PLUG,
COIL, or SWITCH BOX" . Sounds like a good place to start testing.
Oldman570
vettman
Thanks all. I've got my homework cut out for me for a while . Will try all responses. Thanks again
