I have a 1960 Johnson Seahorse CD17 5.5 hp with a bad float. Is 396514 the right OEM part number? If so, I'm having trouble finding anyone who carries it. Any thoughts on a good dealer with a quick turn around? I'm itching to get back on the water.
If you really, really, only want the float, the original OMC part # was 0375919, and was replaced by 0396514. So yes, you have the right part number.
I know you are in a hurry, but once you go to the trouble of getting into the carb, might as well rebuild them, right? Here are a couple of links that have the rebuild kits (including a new float):
Thanks, the carb rebuild is how I came across the float problem. While I was at it, New fuel lines, in line filter, gas tank, plugs, and fuel pump. Hopefully this keeps me on the water for a while.
So this motor is going to be the death of me. I got all of the new parts in and I have a new overheating problem. Does this motor have a screen on that could be clogged? I ran it for about an hour before it quit.
