CD 17 carb rebuild quesitons
troyhuck
Does anyone know how to get the packing nut for the slow speed jet off. I haven't even started the rebuild and I'm already behind. haha. Also, this is my first carb rebuild. If anyone has advice or especially diagrams, that would be amazing. It's a 1960 Johnson seahorse 5.5 hp CD 17. I have the sierra carb kit.
nwcove
a 7/16 wrench usually works well. go to marineengine dot com for an exploded view.
kbait
I had one really stuck just the other day. I put the carb in a vice, a little pb-blaster on the threads, and 7/16 box end wrench. Try tightening/loosening for a bit to let the blaster penetrant in, then it should start to move and come out.. especially when held in a vice so you can get some purchase. Wire brush the threads when it's removed, and use just a dab of white lithium grease upon re-assembly.
Also, your sierra kit won't have a new float. If yours is iffy, the BRP (oem) part number is 396514.
Good luck!
