Steve Mahler
Thread starter- Joined
- Oct 10, 2006
- 361
I have a small antique runabout with my trusty late 60s Johnson 20hp mounted, forward controls etc, just had it in the water first time this weekend.
The cavitation plate is dead even with the bottom of the (nearly flat) hull. Yet just as she digs in to go on plane it is like someone steps on the clutch - RPMs shoot up, loose acceleration. I pull throttle back, she bites back in, and will run right up to that same point again.
Can I assume this is cavitation, and the solution is to mount the outboard a bit lower? how much lower? another inch make a difference?
