cavitation plate height?
tuna troller
how low should the cavitation plate be below the transom? and on the 1980 50hp evinrude witch is the cavitation plate?
F_R
Honorary Supreme Mariner
Re: cavitation plate height?
It is the flat plate above the propeller. It normally runs even with the bottom of the boat, or slightly below. Experimentation is the rule. Run it as high as you can without excessive cavitation/ventilation. You will know when that happens. Having said all that, many go-faster boats run motors considerably higher than that. But those people also put up with an awful lot of ventilation for a go-fast trade-off.
tashasdaddy
as said it is an experiment. from even with keel to 1 1/2 inches above. it depends on the boat and motor combination, trim and tilt all have to work together to get the optimum set up.
wilde1j
At WOT, the plate should NOT be covered with water. If it is, come up a hole and check again. Also, after adjusting, try some fast tight turns. If it doesn't cavitate, it's OK. If it does, back off one hole. It's always found empirically.
BTW, most hull manufacturer boats have motors rigged too deep (never get a caviation complaint). The downside is a slower boat and worse, one that uses considerably more fuel. My boat almost always runs offshore for 1.5 to 2.5 hours each way. My fuel use dropped 20% by getting the "x" dimension right.
Sparkadelic
Thanks for the easy to understand replies. This will/has helped me too.
