Cavitating???
JoshOnt
Hello, so I have a 14ft boat with a 50 HP mercury on it. It seems to run fine with two people but on the rare time it will plane out it starts to cavitate. I am hoping to check tomorrow for a spun hub but if it is not, anyone have an idea what might be going on?
coolbri70
Re: Cavitating???
not properly trimmed? motor mounted too high? hook in the hull?
JoshOnt
Re: Cavitating???
Trim is down all the way and it still happens. Also will search that up and see what I can find.
foodfisher
Re: Cavitating???
Trim all the way down on an engine mounted too high won't fix it.
JoshOnt
Re: Cavitating???
The edge of my prop is worn to the metal and is damaged. The black paint has "bubbles" in it. That is the best way to describe it. I am not very good with props as you can tell.
coolbri70
Re: Cavitating???
maybe venting and cavitating?
coolbri70
Re: Cavitating???
are you losing thrust completely? coming off plane?
JoshOnt
Re: Cavitating???
I am coming off plane and only going slowly, but I am having a hard time getting on a good plane. Will get 3/4 way there and stay there.
foodfisher
Re: Cavitating???
Can't swallow a 50 cavitating anything without blowing itself up. Has to be ventilation sucking air from somewhere.
JoshOnt
Re: Cavitating???
Where would it be getting air from? I had a fin put on to push water down and keep air out
Howard Sterndrive
Re: Cavitating???
is this boat new to you? Have you had it working right before?
short shaft motor on 20" transom?
JoshOnt
Re: Cavitating???
Boat is new to me, and I am not sure the transforms height.
JoshOnt
Re: Cavitating???
I have looked and I don't think I am able to move then engine down on the transom.
foodfisher
Re: Cavitating???
If you can get up on plane, I don't think it's a spun prop. After getting on plane you try to accelerate and the prop busts loose, the prop is too high in the water and sucking air/ventilating. The only solution is lower the prop or get your fat buddies to sit in the aft portion of the boat.
JoshOnt
Re: Cavitating???
Okay well I had me 115 pounds, father 140 pounds and a friend who was 220 all in the boat and we will went slow. I would not pick up any speed. Also I have got the boat to plane ONCE! This was with just me and my father, it lasted for about 15 second till I gave it more gas and tried to go a bit faster.
