Oshkosh1
Ensign
- Jun 8, 2009
- 968
What else is there!
My son and I were out yesterday when I started loosing power. I immediately headed toward shore but ended up DIW about 1 mile from the landing. The engine gradually lost power until it just slowly died out. I popped the cover and the engine was REAL hot...although the water temp gauge never indicated any high temp. I was towed in, then allowed it to cool overnight.
Soooooo...I did a compression test. BAD...REAL BAD.
For reference...I did a CT about a month ago and had 135 across the board(dry).
Now...subtract 100psi. 35-40psi on Cyl 1-5, #6 was the "strong" one at a whopping 60#
Squirting a little oil did nothing to improve the numbers...
I had it running PERFECTLY on muffs just prior to taking it out. Purred like a kitten, not a stumble, hesitation...plenty of water flowing through etc...
Any help is appreciated.
