Carrier bearing
Projectboater
1994 force 90 outboard. Pulling the carrier bearing out it won’t go beyond the threads to the retainer nut. I have punched the pin out, heater the casing but it’s bending my puller. Does this carrier bearing thread out?
jerryjerry05
Did you undo the slotted screw on the side of the nosecone?
If yes? Possible the linkage fell down and is blocking the removal.
If it's the newer style it too can have pieces fall inside and cause problems??
Try sliding the carrier back in and then turn the drive upside down and shake it and try pulling it out again.
The 94 was the change over point from Force drives to all Mercury.
A serial# or a few pics of the drive will help.
You might have to remove the shift rod cover to access the parts??
Pics, you need 5 posts to add pics.
Try photo shop or any photo sharing sites??
