Installing carpet on boat floor, what kind of glue do you suggest? It is fiberglass floor, boat is used in salt water, carpet is indoor/ outdoor type. <br /><br />Also installing seats, one aluminum pedestal swivel arm chair and one sleeper seat, problem is floor boards are not removable and only one inch above hull (maybe less on sides) , do i just screw them into the fiberglass covered plywood floor boards or use some type of anchoring system? <br /><br />The swivel seat has a large base and backing plate but i will be unable to get the backing plate into place without cutting out my perfectly good floor. I do not want to do that. Suggestions?<br /><br />Thanks in advance for your responses
