Card help
huntingtheworld
79 evenrude 55hp
Motor runs bad planning out.if I hit the choke its fine.what is stock adjustments ?
Joe Reeves
Re: Card help
No idea what a "stock" adjustment is.
You've described a engine with fouled carburetors.... remove, clean, and rebuild them.
huntingtheworld
Re: Card help
What does adjustable screw on the carb do? Someone has been messing with the boat before me and now it want idle and has to be choked to plain out.im going to clean it tomm but wondering how many turns is about normal on the adjustment.
boobie
Re: Card help
There are no adjustable jets on a '79 55 hp. They are fixed. Are you talking about the idle speed screw?? Post a model # ??
huntingtheworld
Re: Card help
Model 55975c
I'm just trying to get both carbs somewhat the same when I get does with the rebuild.
I think it's the idle screw.
Re: Card help
You have to accept the fact that there are no user mixture adjustments on these carburetors !-----What you think to be an adjustment is merely a plug that should be tight.---When you choke the motor additional fuel gets into the motor.-----This clearly indicates blockage in the carburetors !
huntingtheworld
Re: Card help
Ok I took the top carb down and their are 2 long tubes that pickup gas in the bowl.i found the skinny tube broke that goes in the big tube.i think the low speed pickup tube.how do I replace it? Iboats keeps giving me errors when posting a pic.
Re: Card help
That tube is pressed in at the time of manufacturing.------------Not considered removable.---Find another carburetor or body.
Joe Reeves
Re: Card help
Also, there is a high speed jet in each carburetor (2 total). They are horizontal and in the bottom center portion of the float chamber, located way in back of the float bowl drain screws.
Make sure that they are perfectly clean as fuel must flow freely thru them before flowing to any other fuel passageway.
huntingtheworld
Re: Card help
Does anyone know the carb part number? I have had no luck finding a carb.
Re: Card help
Sorry, but there is only one high speed jet per carburetor.-------It always helps to post your location to find good used parts.
Joe Reeves
Re: Card help
I realized my typo after inserting my reply. For some reason I was thinking 85hp (sigh). I edited/corrected that high speed jet reply.
New top carburetor bodies have been unavailable for some time.
The short shaft (15") engine carburetor #389293 since 1981.
The long shaft (20") engine carburetor #389587 since 1993.
Both carburetors listed between $150 and $190 at those times.
However, those are the part numbers which may help you find a good used one.
huntingtheworld
Re: Card help
Alabama USA
