carby flooding
nogoals
hi could somebody please tell me what height
i need to set the carby floats on my mariner
80 1983 outboard????
carbys are flooding and the engine will not start
welcome aboard
carnac says .....need more information
did you rebuild the carbs? is this a new to you motor? is this a new problem?
most rebuild kits have carburetor float measurements. if they dont, the manual does.
nogoals
it's a new problem, was running fine then would only
start cold turn it off 10 mins later wouldn't start at all
so i decided to give the carbys a clean, being new to outboards i moved the float setting and now i try and
start it and it floods.
got plenty of compression and good spark
your first problem was most likely dirt in the carburetors. then you adjusted the float and now its flooding.
so pull the carbs back off, set the float height correctly. then install and link-n-sync
