carburetor
Kongblom
Hi All... I have a johnson elektromatic 40 hp 1968 the other day when I squishing the fuel pump, I noticed that just before it was it get really hard, gasoline splashed out of a small hole next to The Lean/Rich adjustment knob in The carburetor .... Is that normal...??
No it is not.----Possibly there is dirt / gum in the carburetor from it sitting with fuel in the carburetor for a long time.----Fairly easy to clean and inspect carburetor .---On thhat motor it means moving starter and generator out of the way.-----Likely the float / float valve is stuck.--Have you tried a gentle tap on carburetor to see if that helps.
F_R
Float valve is not closing. Possible dirt holding it open. Otherwise, possible defective (worn out) float valve, or defective (not floating) float, or just plain crudded up with old gas.
