Carburetor question, low speed operation, Evinrude, 8hp, 1986
SassafrasSteve
The engine will not run at low speed. If I pull the choke 1/2 out it will run very roughly at low speed. It seems okay at higher speeds. I've removed and disassembled the carb, soaked it in Seafoam, and cleaned every passage with spray cleaner. No improvement.
I realize that I'm not sure how this carb works. There is a second fuel line connected to the carb at the low speed nipple (14). See below. What is the function of this line? Could this line/functionality be the source of the problem? Thanks.
