carburetor problems
80viph15
I have a 1980 80 HP mercury. The only way I can get it to start is by using starting fluid. I know this is not good on any engine but.is this a kit or just a cleaning carb problem?
M
Maxz695
Guest
Re: carburetor problems
Do a total rebuild including everything that comes with a complete carburetor kit. Gaskets needles seats jets etc.If you still have a problem rebuild the fuel pump diaphram and all gaskest. Before doing this check all fuel lines for cracks and crud from deteriorating hoses on the inside.Clean any screens and check filters for clogs. Make sure you use alot of carb cleaner in the carb ports to clear all debris. then blow them out with compressed air.
j_martin
Your 2 cycle engine gets all it's lubrication in the fuel. Not only does starting fluid have no lubricity, it also washes off what oil residue is present. The first part it hits is the connecting rod big end.
Put 2 cycle mixed fuel in a spray bottle and use that instead.
80viph15
Well I have done some testing and the fuel pump is not pumping when I turn over the motor! Have talked to several boat mechanics and they have said the compression is bad and I have mechanical experience on autos. I guess what I am trying to say is I have never seen a motor lose compression from sitting up for three months cause that is how long it sat between cranks.
Chris1956
Honorary Supreme Mariner
Motors with low compression do not start well or maybe at all. You may have gunked up rings. When it was parked, it had good compression?
You can try to clean up the cylinders with some Seafoam. Tilt it up and dump some Seafoam into the plug holes and let her sit for a day or so. Maybe the rings will loosen up.
80viph15
Thank you Chris for advice. When she was last parked she would crank and run on her own....prime the bulb choke one time and voila! Just couldn't understand it! Not a two store or boat motor mechanic by any means.
80viph15
If needed how hard is it to re-ring and replace the bearings? I do have internal motor experience just on autos though.
Mi duckdown
I would check the compression myself, to make sure there diagnose is correct.
Then go from there. .02
80viph15
Going to check it as soon as I get home. Stupid question if the compression is above 70psi on all four cylinders would that be okay? I am not sure what it should be.
Mi duckdown
Check compression and let us Know. after rereading the post. It sounds like those mechs are guessing. Did they actually DO a compression check?
80viph15
Duck I just explained over the phone. I have checked 1, 2, and 3 and they are all above 100psi ( I.e.1=110 2=108 3=106). Can't get to number four with my tester so gotta take bottom sroul off the motor to be able too.
Mi duckdown
Those are good nunmbers. After you check the bottom, then your mind is at rest. Then the above posts will come into play.
and don't use strarting fluid EVER/ never
80viph15
Well number 4 has 99. This is just puzzling me! Gonna try and find a whole fuel pump assembly and replace it and diaphragm gaskets.:confused:
Chris1956
The hard/no start problem is not a fuel pump issue, if you can fill the carb bowls with the primer bulb. Is the choke working? Are you choking the crap out of the motor? You need to set the cold start lever all the way up, hold the choke button down and crank her until she starts.
80viph15
Tried and still no luck. Just going to take to a local dealer if I can't figure it out soon.
80viph15
Replacing diaphragm and gaskets tomorrow. Will let everyone know how it goes and thanks for all the insight and advice!
80viph15
aussie the choke is working properly but the motor is 30 yrs old and has never had any kind of maintenance work ever done to it. I am just thinking that the diaphragm is wore out because in my little bit of experience they are made to be tight. The one i am changing has gotten extremely loose so... I think that this is causing it not to get the right vaccum pressure that it needs to function properly.
stickerhard
I have a 1979 80 merc and its doing the same thing as yours and it is the carbs.
80viph15
well sticker i have actually put new kits in mine new fuel lines, filters, plugs, etc... I have cleaned the carbs till i was blue in the face soaking in seafoam you name it i tried it. Then I was rewiring the boat and fixing to reinstall the carburetors I took a chance.... I turned the motor over with the fuel line off and no fuel pulsating! So here i am...
