Re: Carburetor leak
Well i got the leak fixed, it was the float, and as before i started, i'm only getting about 4000 rpm WOT with just muffs on and the prop not engaged. I started this project cause the motor will not plane out the boat and its a 15ft Bumble Bee so should be plenty of motor, and i've already changed the prop now i need to find out what the problem is. i read in here that maybe a trigger or trigger wire? Any input
