rusty bolts
Thread starter- Joined
- Aug 20, 2004
- 148
Carburetor idenification 1987 460 omc cobra ,I?m having troubles with the carburetor running rich at low rpm about 550 650 rpm. Carburetor was rebuilt last year at a local carb shop that has since closed its doors ..The motor will run and shutter just a bit a bit every 20 seconds or so and then after it just will pop and die I can keep the motor running if I up the rpm to about 800 . The Butterfly?s are a little wet when I look in the carb. After it stalls .The barrels area bit black and so are the plugs. I have tried to adjust the idle mixture screws and it seems that no matter where I turn them nothing changes / I start at 1 and ? turns .
The #s on the carburetor are E6JFB and A6F13 I think this a 450 cfm carb.Is that carb way to small for the 460 or is it the recommend one that omc put on it?
The Service manual has the #s at e6J9510 fb and Holley l50399 does anyone know what size this is . I need to know what carburetor to put on it so it will be right. I aim at the point that I will just buy a new one .The points and timing are on the money cap and rotor. points new, may need wires. .working on that. The motor has 500 hours .
Any help will be thank full,
