Cajun Mike
- Jul 26, 2010
- 4
I own a 2008 2 cycle 50HP Electric start Yahama. The problem I have is that when I go to start the engine for the first time, I have to remove the cover and manually reach in behind the carburator cover and close the choke in order to get the engine started. After the first inital starting, it starts fine. For some reason Yahama has elected not to put any type of external choke on the on the engine cover. How can I adjust the carburator so that I don't have to fight the cover removal problem. If you don't choke it you will just about run down the battery before it starts. Can someone please help me out? I've taken it to the dealer and $116.00 later it's still doing the same thing. He did replace the spark plugs for the $116.00. Thanks, Cajun MIke
