carburator jets for high altitude
perucho
I have problems with my Johson 175HP, 1995 when operating at a lake 5400 feet above sea level. When pulling a skier and giving it full throttle , it stalls. This did not happened at sea level. Johson factory told me I need to change the carburator jets (jet size: 70 D, part no. 68 333211) They can not sell directly to me but through a dealer. All dealers I have contacted don't have it and can't get it. Can someone advise me in this matter?<br />Manuel
AUGIDAWG
Re: carburator jets for high altitude
My 95' 200 runs terrible at 5000 feet.<br />You will need to re-jet, and re-prop to a 2" lower pitch.
walleyehed
2" pitch drop won't get it at 5000ft+.<br /> You need to go .001 leaner for every 1500ft above sea-level.<br /> Best Marine, in Denver, CO. can fix you up. I don't have the number here but call info for Denver.<br /> BTW, figure about 2" pitch drop for every 2500ft. I've done a ton of testing on this, and this is as close as you can get, as a starting point........... :)
backdraft
perucho, All my boating is done at altitudes of 4500 to 7ooo feet. I had to drop from a 19 to a 13 for a couple of the lakes. Power is down no matter what you do. Your main objective is the idle and off line mixtures. Slower application of the throttle is needed as well. Top end mixture is better run a little rich if plug fouling is not a problem. The prop pitch is the most important problem to rectify. Experimenting is the only way. Sometimes ,taking the carb baffle off helps a little. Sometimes the motor cover has to be vented. experiment. nevjb
AUGIDAWG
Can you tell us a good way to vent the cover?
walleyehed
The cover IS vented.....<br /> At high-altitude you have less air, which also means less restriction due to vacume.<br /> If the cover wasn't vented, it wouldn't run well at all........... :)
backdraft
As stated above , all covers are vented but some not enough. Usually around the top rear of the covers there is a vent. This has to be enlarged on some motors to get enough air especially above 6000 feet. Johnson and evinrude 15's are notorious for needing more air intake. Honda's 4 stroke are virtually dogs above 5000 feet. THERE ARE EXCEPTIONS. The bigger motors like yours have a stalling problem at 5 to 6 k due to the thin air. It can be overcome with a lot of on lake work. The top end is not quite so noticeably because of the hp you are cranking out and have undoubtedly changed props a couple of times. nevjb
