carbs
mtirillo
If I spray carb cleaner in the carbs when the engine is running to try to flush anything out could I do harm? The motor runs fine till it hits about 5000 rpms then falls flat on its face? 140 Johnson 2 stroke motor.boat.jpg
Cannondale
Re: carbs
You'll get better results with SeaFoam spray cleaner.
Re: carbs
If I spray carb cleaner in the carbs when the engine is running to try to flush anything out could I do harm? The motor runs fine till it hits about 5000 rpms then falls flat on its face? 140 Johnson 2 stroke motor.View attachment 74176
Ayuh,... Welcome Aboard,...
Yes,.. Doin' that could cause harm, 'n won't do a danm thing to Help your Problem...
If by chance it's a Carb Problem, it's in the Inside that needs cleanin',...
They need to be taken apart,.. Rebuilt to do that....
Hi-rpm miss could be the fuel tank, the lines, the filter, or the pump....
Diagnosis keeps ya from rebuildin' the wrong things 1st....;)
Bifflefan
Re: carbs
Probably not going to help.
You need to figure out what is causing the issue.
Lack of fuel, lack of spark. Maybe its the plugs, wires or something like that.
Possible that something is in a carb jet, or the fuel pump is not keeping up.
Just spraying cleaner in the carb will just lean out the mix and cause some damage to the engine.
mtirillo
Re: carbs
Thanks guys, I will check with all the fuel lines and go from there..:)
robert graham
Re: carbs
Sounds to me like your motor is running great, but the fuel delivery system just can't keep up with the required flow at 5000RPM's, maybe a bad or weak fuel pump, a restriction somewhere in the fuel system, maybe a partially plugged filter screen, etc. Start at the tank pick-up, fittings, primer bulb, fuel filter, fuel pump, etc., just work your way up to the carbs. Good Luck!
