carbs
teemercer1979
I have a 1981 merc 115 with 3 carbs. I just replaced the top gears for the starter today and put it in the water. I noticed fuel leakage from side of the 3rd lower carb and the face of itis leaking too. This is the only one acting up. When i give it gas it boggs down and shuts off. can anyone help? Thanks
north40
Re: carbs
Most likely your float needle valve is stuck open. Likely cause is a piece of trash or varnish deposit. Take carb apart and clean out. Good luck<br /><br />Bob
studlymandingo
Re: carbs
Deep Creep may be of some help as well. Do a "search" with the red button above.
teemercer1979
Re: carbs
Originally posted by teemercer:<br /> I have a 1981 merc 115 with 3 carbs. I just replaced the top gears for the starter today and put it in the water. I noticed fuel leakage from side of the 3rd lower carb and the face of itis leaking too. This is the only one acting up. When i give it gas it boggs down and shuts off. can anyone help? Thanks
what about tapping the carb with screw driver???????????????????????????????????
teemercer1979
Re: carbs
whats up chief. you think the screw driver thing will work??
Kevin W
Re: carbs
most likely trash in the float.<br />it happend to mine several times since we switched over to gas with ethanol in it.<br />the ethanol dislodges deposits and clogs up things.<br />i would clean the carbs and add a better fuel filter b4 the carbs.
Laotzu
Re: carbs
After you clean the carbs, try some Stabil in the gas. Keeps the gas fresh over time if you don't cruise a lot and also keeps the carbs clean. Worth the few $$ it costs per tank.<br /><br />Jerry
deejaycee_2000
Re: carbs
clean those carbs properly, happened to me, soaked it in carb cleaner for 24 hours and now good as new ...
