Carbs rebuild
DavidKnapp
When you rebuild the carbs on 140 it there any special tricks I should look out for or is it like rebuilding automotive carbs
wired247
Re: Carbs rebuild
Its easier . There is no accelerator circuit to speak of. Hose out all the passages with carb cleaner and make sure you set the floats correctly. You can pull the soft plugs if you feel like it but the carb cleaner through the passages really does the same thing. Is it a crossflow or a looper engine?
