Re: Carbon in my 225 optimax
No KC, you make good points, and ask good questions! The Opti's are just a little different animal. The injectors are no more fragile than any other injector, but you have to remember where they are... mounted in the combustion chamber not in the intake manifold. <br /><br />At no time is an EFI injector subjected to compression, whereas, a DFI is...<br /><br />If even the slightest amount of oil causes the least amount of "hydrolock" then the injector pin is likely to break. That pin is nowhere near the mass of a connecting rod. (physics again, fluid will not compress)Parts built as strong as a diesel will fail under the same cirumstances.<br /><br />As for adding "seafoam" to the fuel, I really dont think it will harm it, but i wouldn't add more than a can for 30 gallons. It will help keep the fuel system clean, (no doubt about it) but "quickclean" is a Mercury product, tested to be compatible. <br /><br />This is the time and place to have these discussions, in an open forum... Better than after any damage is done. It's my priveledge to try to help people who want to do things right. I sometimes get frustrated so I am now apologizing to anyone I may have made uncomfortable...
