carb synchronizing
double-o
my 87 mercury 115hp has sat for three years <br />and i was told to have th e carbs synced. is that a rule of thumb or is unnecessary. the<br />motor runs fine so far
kenthrussell
Re: carb synchronizing
Hi there to syn your carbs is not needed as long as they all open up together or very close when you open the throttle.....
12Footer
If it runs fine, they are most likely ok,and don't need to be synced. But if you have had problems with lean-running carbs, by all means,take it to a marina that has gauges.<br />If one is running too lean, it will damage the cylinders it supplies over time.
Hitman65
Good morning Double-O and Kent,<br />As a rule we never resync carbs unless we have known problem or have taken the carbs off for a major repair. But Kent, syncing the carbs is not really based just on there opening together. It is really a measure of the amount of vacume pulled by each cylinder. You use the (normally) #1 as a base and macth the rest of the cylinders to it. For example if #1 is pulling 10 lbs at idle then I would adjust the other carbs to 10 lbs also then they would all be sync'ed.<br /><br />Hope this helps,<br /><br />Hitman
