Carb settings for 4 stroke 15hp
Limige01
I have a 1999 evinrude 15hp 4 stroke
model e15r4eeb
guy before me was messing with the idle screw. Throttle response was bad and it wanted to stall under hard acceleration. He got it better but before he did I checked the setting and it was no where near the standard 1.5-2.5 turns out. I stead it was about 8 turns out.
can someone give me the proper spec for this carb. If it indeed is out I will need to pull it and clean it properly and figure out why it's so far out.
Vic.S
model e15r4eeb
Four turns out See http://162.144.28.33/lib/evinrude/manuals/1990-2001johnsonevinrude.html#/168
See sections 3-22 and 3-23 in the same manual for details of overhaul of this carb
Limige01
Thanks
what do you make of this between carb and motor
Limige01
It appears to me someone shoved a tube inside the nipple. Is it supposed to look that way?
they had a piece of hose over it but not a cap
Honorary Supreme Mariner
That nipple may be used for the remote electric start models with the electric primer.----Capped off in manual start models.---May have a look at one later today or tomorrow to see.
