Joseph Elliott
Thread starter- Joined
- May 14, 2013
- 5
Hello I have been reading through many of the posts about rebuilding carbs and am completely confused on how to set them once rebuilt. The various posts mention adjusting needle valves but I cannot find any on my carb. Are they referring to the idle orifice, intermediate orifice, and high speed orifice plugs that are behind the various bolts? If so do you remove the bolt, adjust the orifice plug, then put the bolt back in so the motor can adjust or can you leave the bolt out to make the incremental adjustments to the orifice plugs?
I would appreciate it if someone could hold my hand and guide me in this matter, I have never rebuilt and set a pair of carbs before. I have the repair manual unfortunately there is nothing in it on setting the carbs. I should also mention I do not have a tach but will buy one if I need to.
