Carb rebuild questions for 1988 Mariner 150 and fuel system check.
a69nova
My carbs are in need of a rebuild on my 1988 Mariner 150 serial # OB279500. How involved difficult of a job is this, and where do I start to look for the rebuild kits? I am mechanically inclined and could handle the rebuild, but I am a little nervous about setting them back up and tuning them if need be. Would the settings have to be readjusted? Anything tips or info would be appreciated. Also have noticed that the carbs and immediate area around carbs are pretty well saturated with fuel/oil as well as dirt. Is this normal? There is no known fuel line thats blown, but my fear is that some lines maybe dry rotted and will need to be replaced. Dont even know where to start:facepalm: Thanks Mike
carholme
Re: Carb rebuild questions for 1988 Mariner 150 and fuel system check.
I sent you the parts list for your engine the other day. Did you have a problem with it? You will see the carb kits under Carburetor.
Gerry
a69nova
Thanks Gerry, I wasnt able to open it at work. Im going try when I get home. Have you ever rebuilt these?
I rebuilt the carbs on my '93 Merc 150HPV6. It was not difficult. Some of the V6 Mercs do not have idle mixture adjustment, however, my motor has six of them. It took a bit of time to get them adjusted properly. Too lean and the motor will not accelerate above idle. Too rich and she idles poorly. Actually it was easier to adjust than the three idle mixtures on my Merc 1500 Inline 6, for some reason. That motor was finicky.
mgjtkt
Take plenty of pictures of EVERYTHING before starting.
