baxtr
Thread starter- Joined
- Jul 16, 2006
- 387
Ok, here is one that ticks me off a bit.
Force 125 1989 1251X9B
Numbers on carb body TC 101A 809 66406 1
ok, so I tore apart the 1st carb today, here is my issue:
the kit came with 6 little brass caps
Anyway, On both of my carbs, only 5 of those caps are installed, and one of them has a hole punched in it. hard to see, but it is pictured below.
why is one missing? and one has a hole in it? should I leave the one missing? and leave the hole in?
also, the bigger problem, I got 3 of the caps off, the forth one was giving me problems, and then went all the way in instead :'( :'( :'(
it is the one right by the idle mixture screw directly below the brass bypass tube that runs throught the carb, I don't know how to get it out now, it is way in there. does that bypass tube run through to that cap? can I pull the bypass out and get to the plug that way?
One other thing, the bigger silver cap in the first pic was held in place with some sort of glue, what do you recommend?
Other than that, it's a breeze ;D
