Re: Carb rebuild on 88 HP SPL Evinrude model E88MSLCER.
Joe Reeves,
Yes, the side where the float mounts to is where I kinda messed up the threw hole or wehere the float bowl attaches. The hole on the throat side or where the butterflies are at is o.k. but if I look threw the hole on the other side the float side of that same hole IO can see where I did mess it up somewhat. Does the thickness cuase a issue if not I am hoping I am all right with the threw hole becuase the diameter is exactly the same as the other threw hole beside it. I will take your advice and go ahead and build that carb and hope for the best. I am just trying to save a buck or 2 and plus I guess you can't learn if you don't do the work yourself. I am looking forward to rebuiilding these carbs and will feel great when it sounds great after rebuilding them. Thanks again for your help, Bob also does fuel go into those 2 threw holes are is it an air venturi kind of thingy. I am just curious.:redface:
Joe Reeves,
