carb question
bullstedman
JUST bought a 1973 evenrude 18 horse 18304a there is a knob for low / rich adjustment and someone has taken off the connecting rod to the carb how can i reset this? So i can start frm original adjustment. And when in gear moter off i have a 1/4 turn slop in propeller is this normal and where is the slop i rebuild transmissions so this is driving me nuts is is hard not to tear it apart.
lindy46
Re: carb question
You can adjust the needle where it screws into the carb. Gently close it and then back it out about 1.5 turns to start. 1/4 turn slop in propeller is normal - just the distance the prop shaft turns before the clutch dog engages the gear.
