Carb question
jennis9
This is a general question about rebuilding a carb... I only ask because some of you may have read that I hired a mechanic that may have taken me for a little more than his talent allowed...
oh, heck, I was ripped off and want to know how bad.
If you take apart a carb to rebuild it - can you tell of the throttle plate is shot/worn? or is this something that you only know if you do a rebuild and then put it back together.
I hope you can only tell after, because that means i didn't just waste $500...
I know, I think JB said it was a 50/50 shot at rebuild anyway (after it was already had it torn apart). I already spent that money and now know we have a worn throttle plate and need a new/rebuilt carb that runs about $600.
(PS - i am looking into flyingfish as recommended in a previous thread... maybe I can get lucky for once)
Maclin
Re: Carb question
The plates themselves do not wear, only the shaft and bushings that the shaft rotates in.
and...
You can tell if the throttle plate shaft bushings are worn while the carb is still attached to the intake manifold :(
a70eliminator
Re: Carb question
You got the hose, $500 is going rate for a full restore, anodizing and everything throttle plate bushings the works, I had the service performed through Holley for a rare unique 4 bbl carb, vintage Nascar, it came back looking new.
jennis9
Re: Carb question
thanks for the clarification. I knew the answer, just wanted to double check.
eliminator, may be coming down your way to get this misake fixed right.
krisnowicki
Re: Carb question
you can get a new not rebuilt carb for most applications for much less.
jennis9
Re: Carb question
i am checking into flyingfish but have not heard back from them - any other suggestions for reputable dealers reselers?
P 0 P E Y E
Re: Carb question
Depends on the kind of carb.
Last year a Carter AFB was redone and put back on for around that price. on a 340 Chrysler marine.
Some "mechanics" will take it to the carb shop and mark it up and you get the hose.
jennis9
Re: Carb question
Thanks popeye, I know about scammers well to much.
Anyone have a suggestion on where to find my carb other than flyingfish - I havent heard from them in two business days - contacted them Weds and Thurs last week.
1389-8490
Merc 140
1895 Starcraft ss210
2bbl mercarb
