Carb question
Storm27m
I just rebuilt the carb off my 93 Evinrude E30TELETA 30hp outboard as part of fixing an ongoing problem. The rebuild went fine, actually easier than I thought. I noticed during the disassembly, one part was called the intermediate air bleed orifice. The orifice was not in the location the manual listed for my carb (2cyl), but was there where the manual said it would be for the 3cyl carb. The two carbs are virtually identical in the manual parts breakdown picture. Could this be a reason for my troubles? Wrong carb? Or are the orifices interchangeable?
At any rate, I'm glad I decided to rebuild the carb. There wasn't much visible dried fuel, but there was some pretty large pieces of debris in the carb, especially under the plastic upper body cover. Enough to where I am going to clean all the fuel lines and check to see if I can take apart and clean the fuel pump too. Also, the needle valve seat was damaged, but not in an area that I would think would affect the running. It was damaged in the screwdriver slots where someones screwdriver slipped and messed up the slot.
Any info on whether I have the right carb or not? Thanks.
Edit/Delete Message
Storm27m
Re: Carb question
Well, got everything back together and the carb rebuild seems to have fixed my misfire. I guess either my manual is wrong or the carbs are interchangeable. Thanks.
