Fiddlefire
Thread starter- Joined
- Jul 9, 2018
- 42
I was looking in the carb section of the card needle adjustments for assorted carb variations by Joe Reves. My motor has 3 carbs that does not seem to be mentioned. It also says on top that it does not cover fixed jet outboards. I'm still a bit new to this and I am wondering if there are any adjustments at all on these carbs. My motor is a 70EL76D. I was looking in what I believe is called marine engine .com that has the entire breakdown of my motor for reference and the only thing that may look adjustable is the idle passage screw. Is this carburetor system being used called a fixed jet carburetor?? I rebuilt all 3 carbs and that screw I took out on each one, cleaned out and soaked over night and a new gasket installed that came with the carb rebuild kits. I guess that one of the things that I am asking as well is that screw a low idle adjustment??
