Volvo Penta AQ125A/270 volvo outdrive on a 83 Bayliner Capri Recently I found out that my gas gauge is a little misleading. Out on the water running fine until I ran out of gas had to get a tow back in. 1 week later I filled the tank (still empty from before) and took her back out to the lake. I usually give the throttle one push to WOT and back to neutral. Started right up like normal then died. Over and over I tried with the same result. I removed the flame arrestor to view the top of the carb to see if It was getting gas. when I push the throttle forward towards WOT I didn't see anything come out of the candy can looking deal (I think its called an Acc.something?) once I reached WOT with the I pushed it back to neutral and gas came out. This seems backwards to me. There is also another straight brass tube that sits over the opening of the carb. I don't know much about carbs. Any help will be appreciated. I'm looking for a good parts place to buy the rebuild kit from(once I save money for it due to the price of Volvo parts). Could this mean that the fuel pump is not working? Did it suck up something and clog the fuel travel path? from reading the posts a fuel/water sep. filter I need to buy and install since there isn't one at all. Is there a filter in the carb? I pulled the top of the carb off and looked inside at the float and bowl 3/4 full with gas float moved freely looked pretty clean inside.<br />Thank you in advance for your time.
